Warning Light, Color Amber, Lamp Type LED, Flashes per Minute 60, Lamp Life 60,000 hr, Lens Design Twist Lock Dome, Lens Material Fresnel Dome, Mounting Surface, Operating Temp. -31 to 150 Degrees F, Power Source 120VAC, Current Drawn .03A AC, Width 5.76", Height 6.48 In, Diameter 5.76", Standards UL, cUL, Includes 1 lens gasket and 1 surface mount gasket Features Color: Amber Height: 6.48" Includes: 1 lens gasket and 1 surface mount gasket Item: Warning Light Operating Temp. : -31 to 150 Degrees F Width: 5.76" Flashes per Minute: 60 Lamp Type: LED Mounting: Surface Power Source: 120VAC Standards: UL, cUL Lens Material: Fresnel Dome Lens Design: Twist Lock Dome Diameter: 5.76" Lamp Life: 60,000 hr. Current Drawn: .03A AC
