product picture
Hydro Flow 160 Degree Mini Flow Spray Stake- Orange - Display Box (100/Box) : J
pin
Hydro Flow 160 degree stake sprayers are great for irrigating containers indoors or outdoors. Side tab indicates spray direction. Recommended operating pressure is 10 - 20 PSI. At 20 PSI, you will get approximately 5 gallons per hour for #742495 and 7 gallons per hour for #742500.
Get the Lowest Price
